Questions that arise from the courses
Hi there, Recently Ive been diving in and learning a lot of information. To pass the National certification exam, do we need to memorize technical charts such as the Amount of Amps per Copper AWG and Aluminum AWG? Or know the exact measurements to which a notch is acceptable? Im sure in the field we could look up a chart to make sure its installed correctly. Anyways, Love the course so far!
Hi Carl, I suspect you are referring to the NHIE?
If so, use the search feature here while waiting for others to respond.
You will get results back that look like this:
