**QUIZ QUESTION…
Which tank will fill up first?
Post your answer on this thread but do not discuss it. Let others have a chance
to figure it out. Winners are REAL inspectors. :mrgreen:
**QUIZ QUESTION…
The one lowest to gravity. Number 4
Three.
fill up means to reach its maximum potential.
Kind of looks like a septic system
3 & 4 at the same time
Tank 2 will fill first
Yep #3 will fill first, edit no tank 2 will fill first!
Tank #4.
Tank 3 cannot reach the top of the tank until tank 4 has reached capacity causing tank 3 to fill above the drain between 3 and 4.
Tank 2. Look at it.
3 & 4
two!
three
If the drawing is accurate then tank #2 will fill first.
3…
You are correct Tom!
John, you changed it from the one I saw. Answer still the same though…#2
Think
Definitely 2. Gotta looks close
Tank 1
How did he change it?
And how is your answer the same since this is your first response?
