Radon Results 4.6 pCi/L
Can we inform the neighborhood regarding the High radon Results just to inform the neighbourhood that they might have high radon hazards for safety reasons? if a property has actionable results i.e 4pCi/L? They might be considering testing their properties too.
That would be like informing the neighbors that someone in their neighborhood had a high CO reading.
However, a lot of service companies require their employees to door hang the immediate area anytime they perform work. People are naturally curious when they see a service vehicle at the neighbor’s house. You might as well capitalize while you have their attention
We’ve done roughly 5000 radon tests since 2014 so I do have a bit of data (granted, roughly compiled in my head) when I say this. Radon is EXTREMELY local. As in, we’ve tested conjoining apartments (separate crawl spaces) that have widely varying results. It is true that some areas generally have higher results but within any area it’s still very localized.
Can you “inform” the neighborhood? Sure… just as you can when there is a sex offender or vicious dog you read about in the news. Are you truly providing a good public service or chasing an ambulance? I lean towards the latter. Using a paying customer’s data? I don’t think there are any SOPs that specifically prohibit it. I’d especially steer clear of mentioning an exact address.
Sure, you can do whatever you wish.
Should you? That’s a question only you can answer for yourself.
Have you done your ‘Due Diligence’ in regards to Privacy Laws??
Yeah, I didn’t think so.
Exactly… …
If it’s permission you’re asking for, you can do whatever you want as long as you’re physically capable and it’s not breaking a law or violating a privacy issue.
I realize that you are trying to hustle up some business, but my two cents, this is not a good way to do that. Something more generic would be to mail out a flier with the EPA radon map showing the percentage of homes that might have a radon level above 4.0, but I think most folks (of the 2-3 percent who will care at all) will respond by buying the Walmart kit instead of calling you for a more expensive radon test.
Around here, the EPA claims, and my testing for over 23 years confirms, that about half of our houses, will test above 4.0. The folks who care already know this, and the rest don’t care. It is a small percentage of folks who hear this for the first time from me.
Yep! I’ve done several duplexes that have had wildly different radon levels.
I think @lhenderson2 has hit the mark.
I could envision a post card informing the public of radon hazards in the area using the EPA map, maybe adding in some cancer stats then offering my testing service. No way would I single out a home, because as said before, homes right next door to one another may have a wide variation in radon levels.
It is like that up here and there isn’t much radon in my area.
