Originally Posted By: jbowman
with case.
A must have for any Home Inspector, Electrician, General Contractor, or Handyman. Already have one? Here's your chance to ge a back up for next to nothing. This raffle is open to anyone. You need not be a member of NACHI to enter.
$2.50 per number. Send your donation ($2.50 x the number of chances) in the form of a check or money order made out to the NACHI Foundation, along with your name, address, telephone # and email address (a business card will due) to:
John Bowman
921 Pennsylvania Avenue
Elmira, New York 14904-2652
(607) 733-2455
Number sales are limited to 300 numbers. Chances of winning are 1:300. Naturally the odds are less if you buy more than one number.
The Model 61-155 takes only seconds to test each outlet and circuit under a full load. The Model 61-155 checks for various wiring conditions, including: correct wiring, polarity reversal, hot/ground reversal and no ground. A simple programming menu gives access to measurements of line voltage, voltage drop under a full load condition, ground-neutral voltage and line impedance. The ground fault circuit interrupter (GFCI) test is performed separately and will disrupt the electrical supply of a functional GFCI if present. The Model 61-155 will also test arc fault circuit interrupters (AFCI)'s to ensure that AFCI breakers protecting the circuit has been installed correctly and are operating.
