Originally Posted By: John Bowman This post was automatically imported from our archived forum.
93 Sold.
207 numbers still available.
Top of the line analizer that will definitely increase the accuracy of your reporting techniques of electrical systems. Simple to operate. Take the guess work out of your reports. Report actual facts and findings.
Test AFCI and GFCI with confidence.
Test line voltage with complete accuracy.
Test voltage drop under a full load.
Test for ground/voltage line impedence.
Easily check for correct wiring, reverse polarity, no ground, and hot/ground reversal.
Not a very popular item - is it?
The cut off for this raffle has been set for November 1st, 2004. For those personnel that have participated - Thank You.
I've tested this particular item and assure you that if I was eligible in these drawings I would not hesitate donating money for numbers. Ask around - talk to other inspectors - this is a top of the line item.
IMPORTANT ANNOUNCEMENT!
Due to circumstances beyond my control, I will not be able to attend the meeting being held in Kingston, ON on the 10th. The drawing for the Sure-Test will instead be held here in Elmira, NY on the 13th at the NY Fingerlakes Chapters Electrical Seminar presented by Joe Tedesco. Maybe Joe will pull the lucky winner!! Sorry for any inconvenience.
