Realtors starting to require sqft measurements, as add on service
Anyone else had realtors/brokers require the home inspector to provide exterior/interior sqft measurements? They are stating this is starting to be a requirement and home inspectors will need to make it an add on service for certain areas.
Never heard of that task being a requirement for home inspectors. If REAs are now requiring it in your state it seems that they would have to get the KY SOP changed in order to make it mandatory.
I tell realtors/brokers that when the temperature is above 80 degrees. they are required to bring me ice cream at the end of the inspection. So far, none of them have added this service in my area.
Looks like both of us are asking for additional services that no one knows about.
That sounds like an appraisal task to me.
Ask the next agent that brings it up to send you the statute, or rule, or whatever, so you can review it.
Don’t fall for the Real Estate Salespeople bullshit of which there is a lot!
There is a liability in quoting square footage if it’s not accurate to the actual measurements. For a period of time here, agents could not use square footage in the listing. They attached a copy of the tax record to it and deferred it to that.
As mentioned above, that is an appraiser’s job and not one of a REA or HI.
Funny coincidence. Just this afternoon I had an out of town client state; “Also, I would like to get a copy of the floor plan if possible”.
That’s a fIrst for me.
That’s pretty good, thanks for the good laugh. Might have to use that one.
Thank you for the information, appreciate it.
Pillar to Post has been providing this for a while in my area. It hasn’t become a “thing” yet. I’ve never been asked but my buddy said his report came with a floor plan report when he bought his home several years ago.
Just use CubiCasa app. It’s free for a simple floor plan without room measurements, it takes a few hours to a day to get the results back. Or spend a little extra and get detailed room measurements. I have done my own houses and it’s very accurate. Doesn’t matter if there is furniture or not.
Interesting. Maybe that’s where he got the idea. I should have been more descriptive he actually wanted me to draw him a floor plan
Where to Find a Home’s Square Footage
When trying to determine the size of a property, there are several reliable sources to check before relying on a home inspection:
Real Estate Listings: The property’s square footage should be clearly stated in the listing information provided by the realtor.
County Auditor Records: Most county auditors provide public access to property sketches and official square footage records online.
Home Inspection Reports: While an inspection report provides a detailed description of the home, calculating exact square footage is not required under InterNACHI standards.
Why Square Footage Appears in Inspection Reports Anyway
Even though measuring a home isn’t a required part of the inspection itself, square footage often factors into the process for a few key reasons:
Inspector Pricing: Many home inspectors determine their base fees and add-on services using the property’s overall square footage.
Verifying Listing Details: Inspectors frequently cross-reference the approximate square footage listed in public records or provided by the client.
Note: If you need exact, certified square footage measurements, those are typically handled by a professional real estate appraiser rather than a home inspector.
I have seen a couple agents walking around the house with the CubiCasa app to provide the home’s layout to their buyer. One client asked me if I do something like that. I said No.
We don’t have a state SOP, regs calls for Nachi or that other association, your choice to follow.
This^^^^^^
Their Prestige package is offered here which includes.
Prestige™**
This includes everything in our Plus and Premium Packages as well as our Healthy Home Packages
Save 30% on added inspection services
  • Computerized Evaluation covering all major items inside and outside the home
  • Report produced on-site
  • Clear, concise Report Summary and color photos
  • PTP360 Interactive 360° Visual Inspection Summary* brings the report to life
  • PTPEstimates to learn the cost of recommended repairs
  • Pillar To Post HomePage personal dashboard to access reports in one place
  • Pillar To Post Connects + Home Services Marketplace one-stop concierge solution
  • Seasonal Maintenance Checklist
  • Customer Satisfaction Commitment
  • PTPFloorPlan with room measurements
  • PTPHomeManual digital owner’s manual for your home
  • Infrared Scan helps detect signs of moisture and electrical overheating
  • Lifetime Maintenance Advisory Service
  • Rodent Inspection (where available)
  • Customer Satisfaction Commitment + Guarantee
  • Healthy Home Package — ideal for those who suffer from allergies, asthma, sinus issues or other breathing disorders, in one report that is easy to read and understand
  • Sampling for molds and common allergens (where qualified)
  • Results provided by a certified 3rd party laboratory
