Read that as 1955 however this forum does not allow edit of title.
Need help on this one as I really struggled with my report comments on this one.
I recommended a contractor come out and give opinion immediately however can someone please tell me what comments you would have on the way this was put together.
Thank you for any helpful answers in advance.
Somehow inviting a river to the inside of a structure seems so wrong.
Obviously they had a enclosed porch at the rear in the past and the doors were the entrance to the basement .
The top picture shows the rear siding under the deck where the old stairs began.
[ATTACH][ATTACH][ATTACH][ATTACH]
To try and explain better that rear addition is built over the old basement stairs and part of top of the stairs is outside allowing water into the underside of the new addition where it flows down the stairs into the drain which is actually placed in front of those doors which lead to nothing but a wall now as the laundry room is on the other side.So the green door is nothing but drywall on the reverse side.
Here is a picture under the deck showing the top of those stairs.
I hope this makes sense. as all pics are below that addition at rear except for the under that deck view .
