Recall: Goodman Manufacturing Company Nov. 2021
Good to know, thanks, Mr. Jonas. :+1:
@gromicko Nick, we really should have a section dedicated to Recall Notices (NOT recall services) to post and be able to easily locate this information.
Yes, good idea. :+1:
OK. I’ll have one built. What do you want the title of the section to be?
Appliance and Household Equipment Recalls.
And to add to this idea, how about a free service for our clients where they can access the list and check their own appliances? I can see the marketing already…
Your InterNACHI inspector will provide you with a resource to check all of your household appliances and equipment for safety and performance recalls…
If you give your clients too much info, they won’t need you. :thinking:
Seems like “Appliance Recall Notices” or just “Recall Notices” would be appropriate.
2021-11-19_222418
Such as a web link the the CSPC site:
Good to know i see these a lot in new builds lately!
From link:…
" Hazard:
The molded plastic drain pan located at the bottom of the evaporator coil, when installed with a residential condensing gas furnace in an up-flow configuration, can overheat, melt, and deform, posing a fire hazard.
Remedy:
Repair"
No Duh!
As opposed to “Replace” “Return” “Refund” etc.
Sorta the same verbiage found in most home inspector’s reports!!
@gromicko
So, how’s it coming???
Saint Nick’s been busy. His alter ego is Santa Claus during the Holidays.
