Receptacle readings
My home shows open ground on all my receptacles including the GFCIs.
I live in a 21 year old home, what the heck?
What do you mean shows? are you a home inspector?
I’m going to be soon?
Just to be sure, try another tester. Might have a burned out light bulb.
It’s a brand new tester.
Lol, it’s made in china so…
I bought 3 from Menards when I first started and had to return 1 because it didn’t work at all.
Wow, just pulled it out of the box and its Klein??
I ain’t saying for sure it’s the tester, just a possibility. Do you have a regular tester like the one below? If so just go from hot to ground and see what it says.
Also, wiggle that tester around if your receptacles are old and well-used. Sometimes they don’t make good contact.
Check ground connections in main panel. I assume you have wire that has a ground?
Well one “good” thing is that GFCI’s do not require, or need, a ground.
A 21 year old home should certainly have grounded receptacles.
Best advice for the next step IMO. Or check a neighbors with the tester to verify it’s operable. From there, since I don’t know your skill level or safety training, call an electrician.
Welcome to our forum, Mark!..enjoy participating. :smiley:
Unless you’re comfortable removing the panel cover and pulling a receptacle out of the wall this is good advice. Otherwise first check the tester on a known good receptacle. If you’re up to the task test a receptacle that shows an open EGC, shut off circuit, pull the device out of the box and take a photo. Then remove the panel cover and take a few photos. Post them here and we can probably diagnose the problem.
The ground on the tester may be broken. That sometimes happens. That is why I carry multiple testers. When one goes bad, it goes in the trash and I grab a new one.
Also for when you show up at an inspection and realize you left your tester plugged into a receptacle at yesterday’s inspection. :grin:
A solenoid tester (wiggy) is your best backup. Learn how to use it.
KNOPP
Open an outlet and look.
Isn’t that dangerous?
