Starting to find receptacles under toilets in new houses. Can’t find any rules on them. Is it OK if they are GFCI? Just doesn’t feel right.
Paul Cummins
Paul Cummins
Must be GFCI protected.
Primarily intended for ‘Heated’ seats and ‘Bidet’s’.
Not a problem. As @jjonas said they’re usually installed at that location for Bidets, heated toilet seats or both, and they should be GFCI protected.
It will once you try the bidet … at least that’s what people tell me!
Wouldn’t the wax ring get in the way of accessing the outlet??
I could never imagine seeing an electrician and a plumber coordinating on something like this and have it actually work. One of them is going to be screwed over. Just not sure which one. Either way, a floor joist is going to be destroyed in the installation.
My fear, if not GFCI protected, could turn out like peeing on an electrical fence…..![]()
We installed one in our master bath for the bidet toilet seat. And, yes, it is gfci protected.
I installed one in the master bath toilet room so the Wife could watch her chick flick movies and I can have the big screen in the living room for the gory ones! In between it’s used to run the industrial strength air purifier. When you get old you need all the help you can get!
Your aim really that bad, huh? ![]()
We have a few of these in our home. The receptacle is mounted in the wall. I can’t believe that anyone’s aim is that bad.
Pure Joy! I do not think I could live without one at this point
I think this would be difficult to plug anything in if it is under the toilet. how would you know it was even there without pulling the toilet unless there is a wire coming out from underneath.
It’s usually mounted in the wall under the tank not the toilet itself.
I see them all the time on new construction and luxury homes.
As long as they are GFCI protected, that’s all that matters.
In case you have to charge your phone or tablet while watching videos as you go.
Little kids take time to develop aim
Older folks lose it at 3am…….
