Reference Library
Hi All,
I want to create a reference library.Any suggestions would be appreciated!
What type of reference library?
Have you download the Ohio codes?
Code books, marketing and business books.
No I haven’t and thanks for the suggestion!
Well here is a start;
https://www.nachi.org/articles.htm
Go for it!
What you need/want in your personal reference library will be very dependent on what type of inspections you perform and where you do them. Much of the content of my library is copyrighted material so I cannot give it to you, but I have attached a dump listing all of the .pdf files in my library. You should be able to figure out what most of them are by the file structure and file name. You will probably be able to find many of them by Googling for them by title and adding them to your own library. Of course, not all of these will be available via the web and many probably won’t be of interest to you, but there are far too many for me to try to filter the list for you
You will also want to include some online resources in your library, such as www.building-center.org which is graciously maintained by some of your colleagues (if you use it, support it).
junk.txt (39.8 KB)
I want to thank everyone for all the advice!
