Robert
Thanks for taking the time to help me.
Ok.
I am doing a detailed excercise with the Rem software.
First question is on doors. The house faces South. I added an insulated door with no storm. I am trying to figure out what the Opaque area is. The door is 30 * 68.
On the North side of the home the door is the same size 30 * 68 and has a storm door.
So how do I add the doors to the software.
I also need help with the Blower Door information. The values I have is 1350 cfm @ 50 pa. (I had the most difficulty with the air leakage module)
I believe the formula is ACH50 = CFM50 X 60/V
The volume I came up with is 39559. The homes Sq. ft. is 2327.
I think I have the appliances and mechanical equipment done right.
On the lighting I need to do detailed but I do not see where the pin based and CFL are. (I see it on the simplified)
On the dishwasher EF. Do you use energy factor or federal standard.
Thanks
If you need I could email you the slides of the excercise.
I really appreciate your help as this is all very new and difficult at times for me.
