Residential plumbing
my name is Devan Lovelace i am doing the plumbing section to get my certification and in the video of the kitchen inspection he mentioned you don’t want to see two P traps beneath the sink why is that. Should everything just go to just one p trap?
First, a second trap is redundant because one trap seal is sufficient to prevent sewer gases from passing. Second, double-trapping could either result in a slow drain or cause siphoning in both traps depending on the volume of water. And third, double trapping is an explicit violation of plumbing codes.
I agree with everything Rich mentioned.
To keep it simple, one P-trap per fixture.
Here’s one that I recently found and wrote up.
thank you for the response that makes more sence
