Originally Posted By: John Bowman This post was automatically imported from our archived forum.
- My definition is from the splice point at which the homeowner is responsible for maintenance and upkeep. Better known as the “Service Drop”. (i.e. from the mast head connection (“Service Point”) down to the meter and from the meter to the panel box).
What I visually inspect - I check for frayed/damaged sheathing of the service drop. I check for a drip loop system. I check for loose or non-existent clamping. I check for loose or broken anchoring. I check for impeding tree branches, and proper clearances.
Most common defects - I take special care in examining older homes that have been recently sided. For some reason I seem to always find anchoring of the mast head or Service Entrance Line a problem. Often I will find where the siding installers have pryed loose or improperly secured a meter base.
- I call it the “Meter Base” and meter. The meter base houses the meter which the power company utilizes in reading exacting measurements of electricity used by the consumer. The power company is responsible for the meter calibration, etc. The consumer is responsible for the meter base. The power company should regularly monitor the condition of the meter base and meter.
What I check for - I check for frayed sheathing entering or exiting the meter base. I check for lack of electrician's putty around the base connector's. I check for looseness of the meter base, and general overall condition of the base.
Most common faults - Lack of weatherproofing around the area where the wire enters the meter base on the top and loose meter bases when older homes have recently had siding installed.
- My definition. Equipment where the power conductors entering the building can be switched off to disconnect the premises’ wiring from the utility power source.
What I check for - Six disconnect limit. Corrosion, damage, missing parts, and anti-oxidizer. I note the size of the service and main breaker.
Most Common Faults - Anti-oxidizer not present on aluminum wire connections, (i.e. Service drop lines and major appliances such as an electric stove).
Originally Posted By: jhagarty This post was automatically imported from our archived forum.
Clarifications are needed in this area. Requirements as to particulars that are inspected are presented as a Minimum standard. Inspectors can independantly exceed those minimum standards based on Education, Certification and E&O Coverages afforded for the exceedances of minimum standard.
Discussions of proposed changes to SOP may be best if the ideas are presented to the SOP Committee. Open public debate may not be the proper venue for discussion regarding SOP and Ethics.
Originally Posted By: dfrend This post was automatically imported from our archived forum.
Quote:
A. The Service Line - My definition is from the splice point at which the homeowner is responsible for maintenance and upkeep. Better known as the "Service Drop". (i.e. from the mast head connection ("Service Point") down to the meter and from the meter to the panel box).
Gotta watch the precise definitions. In the DC area, PEPCO owns the line up to the meter including the meter. In fact, when I worked for State Farm, we would not pay for damage to any part(mast head, meter, etc.) on the Power Company side, because they would cover it.
Your exactly right Daniel. That’s why I wrote “My definition”. Here in my area the homeowner maintains from the mast head down. The meter however is the property and responsibility of the power company.
dfrend wrote:
For a member driven organization? Never heard of such a thing. ... Why can't members discuss their opinions of the SOP's .
I agree that we are Member driven. Should the Member SOP's modifications be discussed in Members Only or in the Open General Forums?
Originally Posted By: jfarsetta This post was automatically imported from our archived forum.
Standards of Practice should stay in line with those of other major orgs. The more comprehensive the SOP, the more likely you will be to get sued for not following it.
As NACHI is entering the E&O arena, and the risk analysis is also measured against our SOP, it would be unwise to liik for bulk changes. Even slight changes to the SOP could have a very negative impact upon this upcoming program which is aimed at providing lower E&O insurance rates to ALL members who choose to participate.
Changing the Standards of Practice is more than simply putting an idea out there. There are legal ramifications which will need to be carefully reviewed by NACHI Corporate Counsel, who is also a member of the ESOP Committee.
-- Joe Farsetta
Illigitimi Non Carborundum
"Dont let the bastards grind you down..."
Joe T,
You are mose certainly a wealth of knowledge and a genuine asset to NACHI and to the many inspectors you help. You neednt be so careful with your words. The only thing I ask, and you have started to do, is to take that vast knowledge and help us apply it within the context of what we are most likely inspecting.
For instance, the service mast question. Your points are well taken, without the technical references. For instance:
"Guys, although that mast may indeed have been approved, keep in mind that that coupling may become a weak point. This is especially true, seeing how this mast doesnt have any supporting line, and appears to be higher than 5' above its last support. Therer are other reasons why it may not be up to NEC standards, like there doesnt appear to be a drip loopp...etc.... Develop a keen eye fr this stuff..."
I dont know... train us to be better, without getting into the technical code. It wont be easy...
-- Joe Farsetta
![icon_lol.gif](upload://zEgbBCXRskkCTwEux7Bi20ZySza.gif) Which one won't be easy. Train us to be better or without getting into the technical code. ![icon_lol.gif](upload://zEgbBCXRskkCTwEux7Bi20ZySza.gif)
Is it safe to continue with my definitions if I so please?[/quote]
