What are your thoughts on filtered vs unfiltered ridge vents?
A filtered ridge vent helps prevent dry powdered snow from blowing into the attic.
Yep, and sideways blowing rain…
What do you think about the concern that the filter will block air flow? I know it is designed to breathe… But do you think the concerns are legitimate? Or much to do about nothing?
The filter is also a way to keep insects, birds and other critters out of the attic.
It is not a problem Dustin.
I know your forum time is limited, but it’s always good to see a post from you Larry!
Thanks, Tom!
