I was on an inspection today and found this. It looks like a chemical type damage. There are two small areas and it did not appear to be hit. The Tar seems to have melted and curled up. The under layer of fiberglass is exposed. I’ve never seen this before. Anyone know what could have made this happen?
I cant seem to add the photo guys sorry. It looks like something hot spilled on it in a splash and welded the tar off and it bubbled up and cooled. The material is sitting there and remained soft and gooey.
It looks like the roof was damaged when it was installed and or someone did some work in the area and damaged warm/hot soft shingles. I do not think that is hail damage, but if you see dents in soft metal like vents, flashing, and rain gutters, then it could also be hail damage.
I even thought it could be from fireworks but the tar is still soft and it doesn’t make sense. I will just document as unknown and recommend repairs by a qualified roofing professional.
