Does this roof have properly installed flashing?
Which flashing(s)?
Please keep in mind this is a message board for Home Inspectors. You are not one; your question and picture are a joke! Go to some other DIY site!
If you’re referring to the counter flashings over the porch, it’s impossible to tell with the picture you posted.
If you have questions concerning a roof issue, I recommended calling a qualified Roofer to take a look at it, and ASAP if it’s leaking.
Is there lockout flashing on the top portion of the roof where it meets the brick? Is the flashing cut into the brick and sealed with the proper sealant? Maybe get up on a ladder and get a closer look. Or maybe hire an inspector who can actually tell you.
Possibly…
Morning, Preston. Hope to find you well and in good spirits today. And welcome to the InterNACHI message board forum.
Don’t mind some of the unfriendly posters. To me a question is worth an unbias answer.
The slope roofs you represent, have 2 different roof covering materials, and only show limited amount of the roof coverings.
That being said. The upper roof covering, being composition shingles, have visible drip edge flashing installed at the gables. Those drip edge flashings appear correctly installed on the gable side by the roofing contractor.
The lower rap-around porch roof is metal roof covering in a standing seam pattern.
Where the metal roof meets the masonry veneer there is a metal head wall flashing. As well it looks sufficiently installed but should have been cut into the masonry, into the brick itself, and not installed or locked in at the head or bed joint.
The expansion an contraction of the metal into that joint will cause premature failure of the mortar over time and may become an entry point for moisture and masonry/mortar repairs.
As well there is a missing section of head wall flashing, be it short, on the gable veneer.
I do not see a sealant/caulking joint were headwall flashing intersects masonry.
No matter what roofing material is used as a roof covering material, head wall flashing, also known as head flashing or counter flashing, is crucial flashing for directing water away from the exterior wall assembly and roof intersections, to prevent leaks.
The downspout should be extended along the porch roof and intersect with, or just above the gutter below.
Hope that helps.
Robert
Is that a regional term? I can’t find that term on the internet.
Lol, got to love auto correct. Kickout is what it should have been.
I concur, Bert.
I stayed away from asking William that question but you bring up a good point. I have never heard that term used be it educationally or as regional slang.
Flashing on the top portion of the roof where it meets the brick is subject to interpretation as to ‘where the top of the brick assembly meets the roof.’
Bricks are not stacked on roofs. Bricks are stacked on each other and do not directly contact but are independent of a roof assembly. If not the roof movement would affect the masonry assembly.
I think he is referring to the wrap around porch “head wall flashing” being tied into the masonry veneer. William quoted “Is the flashing cut into the brick and sealed with the proper sealant?” That would be Head Wall Flashing.
That’s a polite response, but the OP’s photo doesn’t help us much in answering his question. Your blow-up is noble attempt, but it doesn’t really tell us much either. I think the correct response to the post is to advise Mr. Williams to give us some much better photos and some direction in what he suspects are the problems.
Of all the posts concerning your photo and your question, this is the one you choose to respond to?
Actually, NO, it wasn’t!
What are you seeing wrong with it?
