Roof Geometry, included or not
When calculating a roof’s geometry a detached structure is not included. I know typically the rule is “is it attached to the fascia/wall” and if it is (and not a living space), it is not considered. Feel free to correct me if I’m wrong there.
Would you consider this porch attached to the fascia? It looks partly attached to fascia and attached a bit to the roof structure. Am I overanalyzing this? I appreciate any guidance.
Can you post pictures from farther back?
For a WindMit, if there is a space (division) between the flat & main, & the drip edge is visible, it’s not counted unless it’s over an enclosed living space.
I believe it to be included. As you say, structurally attached. When the roof overlaps or bleeds into the next, I include it. The purpose of the roof geometry is to determine its roof shape- in risk of external wind pressure. If that flat roof were to come up, it’s taking a portion of the shingle roof with it. Here is an excerpt from “how to perform a wind mitigation” >buildings and wind > external pressure
