I’m working on the inspection/essay portion of roof inspection course and came across these three items during my “mock” inspection. Would these be considered “in need of correction” or simply cosmetic? pictures of fascia corner decay, lead vent pipe wrap damage, and shingle damage at drip edge flat/slope roof transition. My assessment is at least two (fascia corner and lead wrap) should be corrected. Thanks in advance for feedback.
Would you want these conditions to exist on a home YOU were buying?
Why or Why Not?
Yep. Anything damaged or decayed is a good portion of what your client will be expecting you to identify.
Thanks. That’s what I was thinking, good to have a second set of eyes on it though.
No, I wouldn’t want this on a home I was buying but I’ve often seen things that are considered cosmetic so I just wanted to get another opinion. All three are water intrusion points. Thanks for the response.
BTW, that’s probably a squirrel or similar chewing on that lead flashing. They like it because it is sweet tasting and it helps them manage their teeth. It does make them insane though, lol.
And to add to Ryan’s comments, those squirrels most likely chewed on those damaged shingles as well and may be living rent free in the attic.
haha, could be. I heard they like to chew on that stuff but never saw any examples IRL until now. This is all from the house I live in, so far I’ve not heard anything in the attic but I’m sure I’ve jinxed it now. I have to talk to my landlord about getting these things fixed.
It’s not all about what a client would expect. They have crazy and wild expectations and it is up to us to manage those. This is partially accomplished by following our SOP.
Generally, damage on a home’s exterior has more consequence. For example, peeling paint and bare wood on the exterior will degrade, not so on the interior.
All of your photos would be in my report for repair.
Thanks. I did include all these as in need of correction in the report I submitted for the course.
After looking at the photos how many inspectors would call the tree being near the foundation?
Or the tree stretching over the roof?
Depends on the clearance and visible damage. As pictured, no.
Depends on the overhead clearance and damage.
