Roof inspector did not do the job right and is upset
Hi all, my sister has bought the house and the seller had provided a property inspection report. The property inspection report states “the openings at the chimney flashings” and “improper kick-out flashing at the front roof to the wall connection to divert water away from the exterior cladding into a gutter system”, photos attached as proof. In the process of doing paper work to buy a house, our home buyer agent ordered a roof inspection. The roof inspector came and left really quick, then sent us a report via email. In the roof inspection, he states that:
Description of Roofing System and Condition:
This is a “Villa” style concrete tile roof, which has been installed without an underlayment, as per the manufacturer’s specifications at the time of installation. However, the current code requires a solid roof deck and a minimum 30lb felt underlayment. This roof is in overall fair condition materially and appears to have been installed correctly for the most part. The roof shows wear characteristics of being approximately 30 years old.
General Observations:
  1. There is a build-up of debris in the valley between the garage and the house.
  2. The pipe jacks are not properly sealed.
He did not mention anything about “the openings at the chimney flashings” and “improper kick-out flashing at the front roof to the wall connection to divert water away from the exterior cladding into a gutter system”.
I thought he did not do the job right, so I contacted my home buyer agent to let her know I am very disappointed on that fact that he could not find the problems that the property inspector found. My buyer agent had contacted him and asked him to re-inspect the roof. He said he does not think “the openings at the chimney flashings” needed to be fixed, it’s a minor issue and there is nothing wrong with his roof inspection report and refuses to come back to do the roof inspection. I don’t know what else he missed on the roof inspection. I think “the openings at the chimney flashing” allows water and moisture intrusion that would damage the ceiling and is not a minor issue.
My questions is “Does he do the job right?”.
Note: After receiving his roof inspection report, I expressed my disappointment about the roof inspection report to my buyer agent. My agent contacted the roof inspector and sent the property inspection report to him to show him that he missed some problems stated in the property inspection report on roof.
I think you answered your own question
http://www.nachi.org/forum/data:image/png;base64,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
http://www.nachi.org/forum/data:image/png;base64,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
If you are happy with the inspection(s) and trust that the roof is good shape as is … agree to buy the house.
If you are not satisfied … tell your agent that you would like to look at other properties.
or get another roof inspection
What JB and MT said above.
Let the scrambling (agent/seller) begin…
I was surprised by the fact that the professional roof inspector said that he thinks “openings at the chimney flashings” is a minor issue and does not need to be fixed.
By using common sense, I think that any problems that have potential of causing any damage to the house is considered serious issues, not minor, and should be fixed.
Do you think that he is an irresponsible roof inspector that gave an uneducated argument to defend himself?
What makes you fell that the first inspection is correct and the second isn’t? Why did you use the sellers inspection report?
Nick it is not fair of what you are asking. First there are no pictures, Second things change from one day to the next, Third its not fair to comment about someones work when not there when preformed.
You seem to have a gut feeling so go with it as that’s reasonable and fair. Have 2-3 roofing contractors come out and give you a quote to fix what the roof inspector called a minor issue.
Or
Or
If I am reading this correctly it sounds like your sister did not get her own inspection, but relied on one by the seller. Who instructed her to do this, or was she just trying to save some money. Does she know that she cannot use the findings in that report, or at least, she should not be able to.
Second, If the realtor sent out the roof contractor she is not as liable as he is for any repairs.
Your sister now has a worst case and best case scenarios to help her decide what to do.
Inspector one says the roof is 30 years old and was installed according the standards of the day, which have changed, and points out some issues that should be fixed.
Your sister bought the house after this report(?). Inspector 2 says the roof is OK.
If the roof had failed there would be evidence of that.
Inspections do not fix problems, they just point them out.
Now that your sister knows there may be something wrong with the roof she call one to three qualified contractors for second opinions and quotes to fix it, or she can wait to see if the roof leaks.
