Other than height requirements on roof vents, is there any should/should not on elbows to prevent rain and snow or screens?
Do you have any photos Chris? Your question is vague, three common roof vents in my area are plumbing vents, exhaust vents and attic vents. Defects with them are common. Given the elbow comment I assume you’re referring to plumbing vent(s) which should be 6" above the roof or expected snow depth (7’ if used as an observation, promenade, sun bathing or similar deck). the pipe diameter shouldn’t be restricted less than one pipe size smaller. It’s a plumbing vent, rain inside the pipe shouldn’t cause any concern. Screens are not required in my area, but sometimes installed by handyman/pest guys when clients have critter issues.
What @sfetty said
. I would add that if the pipe is being used as a fresh/combustion air inlet where a concentric vent is not used, it should have elbows to prevent rain/snow entry.
As far as height above the roof surface, your regional weather/climate or local AHJ would dictate the minimum height. In my immediate area, the minimum height is 12” for plumbing and combustion/exhaust vents. Oddly enough, dryer and bathroom exhaust fans can terminate at the roof surface though as long as they have a cover to prevent rain/snow entry.
If you are referring to dryer vents, no screens should be installed.
Your regional weather/climate and AHJ would dictate whether screens are permitted or even a good idea on plumbing vents. In northern regions it could be a bad thing since the screen would freeze/frost over plugging the vent off. Southern climates, frost usually isn’t an issue.
That’s exactly what I was looking for, thank you
Thank you, that was helpful
