Once you have the roof pitch planed, I suggest you go to a builders sight John.
Residential building Inspecting and residential building construction are to different disciplines.
I think anyway. Good luck mate.
Yep.
You might consider adding:
-synthetic underlayment.
-Method used to create valleys.
-valley lining material
-cut, CA cut, open or woven valleys
-Shingle installation method
-Look for racking
-Confirm use of step flashing
Confirm kickout flashing installed where required
-Confirm proper headwall flashing installation
-Staples are OK if allowed by jurisdiction and if properly placed and driven.
-Confirm underlayment is cut out at vents
-Confirm longer nails used for cap shingles or ridge vent
Once they’ve had a chance to heat up, check for adequate bonding.
why wont the roof checklist pdf open for me?
why won’t the roof checklist pdf open for me?
Because this is a 11 year old thread!
where would i find roof inspection examples and checklists?
