Root cellar and APOC bunker?
This was from yesterday’s residential inspection in Dawsonville GA. There was a root cellar or stome shelter on the left side of the home. Growing up in MI these were pretty common in rural areas. Around here I see them every blue moon. Right when I pulled up and seen the flue stack I knew what it was.
But, the other concrete structure down by the creek had me stumped a little bit as what it was intended for. It had a buried pre-cast concrete tank about 12 ft down with CMU block walls embedded in half ground and half above. Someone put a wood cover/roof over it. I was thinking maybe garbage or body disposal? It was full of water. Maybe it was going to be an APO type bunker!
They must have taken the still out before you arrived.
You might be onto something Jeff! You know Dawsonville has some history with the shine. In October we have an event called the Moonshine Festival.
Is that where Awesome Bill is from?
It is! Bill and his son Chase. This was just a few minutes from where they live.
Spring house would be my guess.
Functionality: A small stream or water channel runs through or beside the structure, essential for its cooling purpose. Spring houses used the constant temperature of spring water to preserve perishables before refrigeration.
That’s a good guess and a possibility! But this structure was about 100ft away and maybe 20ft above the creek elevation. And they had that root cellar on the opposite of the property right next to the home.
