The inside of panel is not affected with any moisture. Would you still call this out because of the outside rust?
Thanks
Thanks
Hi to all,
Gary I would note it as a concern, even if it was dry inside it will not remain like that for long.
Regards
Gerry
Gerry
Would you recommend replacement in the near furture, or now?
Thanks
Maintenance Item: Shows indications that it may require repair or replacement anytime during the next five (5) years. ![]()
There is an old Navy saying: IF if moves salute it. IF it does not move Paint it.
Looks like it may not provide the minimum of 3 feet of working space in front of it as well?
Sounds reasonable…I like that. ![]()
Joe
Where is that written at, the 3 feet, I was looking for that very item.
Thanks
Either 110-16, or 110.26 in the NEC
Funny Charley, the same phrase came to mind when I was thinking about it, I would have listed it as a maintenance issue rather than a defect at this time.
Some would say that as the rust isn’t UL listed it has to go!! ![]()
Regards
Gerry
