Does anyone have experience inspecting mobile home frames? At what scale of rust should it be recommended that a mobile home steel frame axle be deemed beyond repair or has a limited life remaining 5-10 years? How do you tell between surface level rust and a rust deterioration that exceeds? Why is it common to button a black vapor barrier underneath the joists leaving the metal frame and metal pipe supports exposed to moisture?
Related topics
| Topic | Replies | Views | Activity | |
| Rust | 9 | 2667 | January 26, 2008 | |
| Lots of steel, lots of rust... | 2 | 3716 | February 28, 2008 | |
| Mobile Home | 4 | 1689 | May 23, 2014 | |
| Inspecting a metal roof | 20 | 19649 | October 23, 2018 | |
| Crawl Space Foundation Beam Cracked? | 8 | 920 | August 29, 2021 |
