S Traps Plumbing
New to the community but I have a question. what should an inspector do if he or she discovers an S trap type connection during an inspection
Mention it in your report and move on.
FYI… are you aware that most EVERY home in America has a minimum of one ‘LEGAL’ S-Trap installed within the home?
Newbie here. Thanks for your response. I figured all newer construction homes built 2000 and up would not have them.
S traps are one of things I briefly mention in an “information” comment to prevent the buyer’s handyman uncle from claiming “Your inspector did not even mention this highly illegal trap???! It needs to be replaced ASAP!”
Morning, Gregory. Pleasure meeting you.
Hope to find you well and welcome to the InterNACHI community forum!
May I recommend, in your report, explain why S-Traps are non compliant in most plumbing drainage fixtures?
Observation: S-traps under the kitchen sink or bathroom sink.
Causation: S-Traps are widely prohibited in modern plumbing codes ‘for most fixtures’ due to their tendency to siphon water out of the trap, which breaks the seal and allows sewer gases into the building. They are, however, still standard in certain applications, such as toilets, where the siphon is managed through an integral, self-refilling design.
Recommend: A licensed plumbing contractor improve the trap design to prevent back siphonage. Act upon any recommendations therein.
Then move on to the next defect in your report.
Hope that helps, Gregory.
Best regards with your endeavors.
Robert Young (CPI) (CPI)
I always called them out, but never really put a whole lot of thought into it. Then a client was adamant that I make sure the home they were buying did not have any. This was due to her being hospitalized due to sewer gas in the home they had previously lived in. It put things into perspective, so I have made sure to put more of an emphasis on it.
I was discussing this with the owner of one of the larger sewer service & plumbing companies a few years later. He asked me if I call out floor drains that do not have trap primers. His whole point to it was that unless a floor drain has a regular source of water going to it, that it is more likely to be a problem than a sink.
No. But it is smart to let homeowners know they should fill them occasionally :wink:
Not necessary in Century Homes with stone foundations!
The old farmhouse I grew up in had S traps everywhere (1911). exactly when the indoor plumbing was added was before my time but the S traps never were a problem. An addition was added where the pantry was in 1967 when Grandpa came to live with us so those were corrected (to P trap). The kitchen was updated in the 90s so that is now a P trap. That leaves the upstairs lavatory and the problem is not the S trap. It is the galvanized pipe that runs to the drain stack. Clogged up solid. Only possible repair will add a P trap and leg behind the wall to the drain stack (don’t want to dig up the floor)
So, along with your FYI for S traps you may want to add a line about galvanized pipe which sometimes accompanies them and will eventually rust shut.
Well I have 2 houses one built in 1987 and one built in 1998, neither have ever has an s-trap installed. Well not in the past 24 years anyways.
So youse gots no terlit inside yer hom?
I write them all up as an improper installation.
In saying that, it is a minor defect that any decent Plumber can easily fix.
Maybe with an AAV.
If legal in your area.
I was thinking replace the S-trap with a P-trap.
I had to use the google to find out if an AAV would prevent an S-trap from being siphoned and it looks like it would work, but as JJ mentioned, some jurisdictions might not “legally” allow them.
An S-trap with an Air Admittance Valve (AAV) (or Studor vent) can stop siphonage, but it is often not considered a proper, code-compliant fix in many jurisdictions because the AAV must be installed on a P-trap, not an S-trap. While the AAV introduces air to prevent negative pressure from pulling the water seal, an S-trap’s design violates modern plumbing codes due to high siphon potential, say Hammerpedia and Oatey. [1, 2, 3, 4]
Key Takeaways:
  • The Problem: S-traps allow water to pull itself out (siphon) when emptying.
  • AAV Function: An AAV (a one-way valve) allows air to enter to break the vacuum, preventing the siphon.
  • Correct Fix: Cut the pipe below the S-trap, install a sanitay tee, add the AAV (studor vent) on the top outlet, and install a P-trap on the side outlet.
  • Code Compliance: AAVs are generally allowed for remodels, but you must check local codes. [1, 2, 3, 4, 5]
How are you going to install a proper p-trap if there is no vent going up the wall?
I didn’t see where the OP ever mentioned anything about the presence or absence of a vent.
Did I miss something?
How many s-traps have you seen tied into a stack?
This is the perfect example of home inspectors that have little knowledge of plumbing.
If an AAV isn’t allowed in your jurisdiction, you will be cutting walls, ceilings and making penetrations into the roof to install a vent system.
Not so easy.
