Join us for the Safety Glazing Class at InterNACHI’s Pennsylvania House of Horrors on July 13, 2021.
This class is designed to explain the various locations where safety glazing is required. The primary emphasis is on residential uses, however many of the requirements are also found in commercial uses. We will look at the most common locations along with the most common misunderstood code requirements. Alternative methods to comply for the code requirements will also be discussed.
Register here: northeasttraininginstitute.com/cm-course/safety-glazing/
