This officially tops them all, I have no idea how this has happened.
Look at the top portion of the waste pipe (gray water) there is a hole in the top that I can stick my finger in (weird I know) Whats even more puzzling is the other part of the pipe that is dripping water, at first I thought how did a rat get in the pipe, well its no rat as a matter of fact its a hair ball that has clogged the line, but I still cant figure out how the hole got there and why there is hardly any water ponding underneath this pipe?? It is such a slow drip. For what its worth I can tell she was blond:) I did not pull the hair out.
Not bad for an Okie…:mrgreen: :mrgreen: :mrgreen: :mrgreen: :mrgreen: …what flavor should they be? Chicken???
Here’s one of the best I’ve run across, over 50" head room in this stoop-space…soap scum and other stuff almost connected numerous times, see all the fragments at the base
I suspect the top hole was from the installation, but the bottom section where the hair is hanging out I cant explain. One would assume that if there was a hole in the bottom water would be ever where but that is not the case here. Directly above is the floor with nothing that could cause this to happen.
Now about the taste test lets just say I would leave that taste test to rookies or anyone wanting a little snack.
Just another angle of pursuit to think about… Any vent pipes missing or capped?? I find a few new constructions with capped vent pipes at the roof left in place… maybe the hole is a “homeowner” fix for a slowwwww drain?? :roll:
