Thnaks again. Karen and Dee can be tough to give approval. This has to be a great course.
It is.
The course includes:
- 43 sections (31,000 words)
- 140 photos and diagrams
- 5 quizzes
- 50 question final exam (drawn from a larger pool)
- Instant grading
- A downloadable, printable certificate of completion
- Accreditations and state approvals
The course covers categories such as:
- Introduction and Scope
- Acknowledgements, Disclaimer, and Forward
- Scope and Approach
- Moisture Moves
- Inspecting for Moisture Instrusion
- Inspectors and Codes
- Moisture-Resistant Roof Systems
- Roof Flashing
- Roof Ventilation and Insulation
- Roof Overhangs and Projections
- Roof Drainage, Gutters and Downspouts
- Moisture-Resistant Wall System
- Checking Windows & Doors
- Flashing of Wall Components
- Check Caulks and Sealants
- Moisture-Resistant Foundations
- Inspecting the Basement Foundation
- Basement Wall Insulation
- Slab on Grade Construction
- Slab on Grade Insulation
- Crawlspaces and Moisture
- Checking Ground Clearances
- Check Wood Preservative
- Alternative Foundations
- Moisture Vapor Control
- Climate Considerations
- Moisture Vapor Problems
- Indoor Humidity Problems
- Air Leakage & Major Moisture Problems
- Vapor Retarder Major Problems
- Mechanical Systems and Moisture
- Construction Phase Inspections
- Water Management & Damage Prevention
- Moisture Control for Homeowners
- Where to Look For Problems
- Bathroom Problems
- Looking in the Utility Room
- Looking for Attic Problems
- Basement Moisture Problems
- Laundry Moisture Problems
- What to Look For Outside
- Checking Roof Moisture Problems
- Conclusion
