Would you recommend a structural engineer based on this crack? The separation of the brick at the mortar joint was about 3 feet long. No other signs of settling…all doors and windows opened and closed good, no inside cracks at all, all the old caulk joints are intact & not separated, all trim is snug with no separations.
Get rid of the tree.It appears to be creating enough pressure on the brick veneer to crack the mortar joints.
A lot of people don’t believe that trees and vines can do such damage…but…they can.
They were bushes. Heres the reason I asked. I did the inspection. Noted it in the report to monitor for future movement. For whatever reason they sold the house 3 months later. The HI who did the inspection recommended they contact an SE. They called me. They called the SE and the SE said don’t worry about it and I said told you so. Just wanted to see what you guys thought and if you would have recommended the SE.
