SE or not?
Originally Posted By: jlybolt
http://www.nachi.org/bbsystem/usrimages/C/Central_Ave_151.JPG ]
[ Image: http://www.nachi.org/bbsystem/usrimages/C/Central_Ave_0011.JPG ]
Originally Posted By: thejnicki
Is this a slab or raised foundation?
Originally Posted By: ccoombs
James
All concrete will crack. The question is if there is a problem with the cracks. An 1/8" of an inch is starting to get large. Most cracks will be straight, more or less. This one has some strange movement to it. But the main sign of an issue is if there is displacement across the crack. This is a sign that something is moving and it should be checked out.
I hope this helps.
Curtis
Its a slab foundation built approx. 1986. Can you please explain displacement? Do you mean widening of the crack? Is this crack enough for one to call for further evaluation? Thanks for the help.
Originally Posted By: mboyett
Mike Boyett
Capital City Inspections
Austin, Tx
www.capcityinspections.com
Originally Posted By: bking
I agree with Mike, nothing is there for a SE, maybe a soils engineer could provide a report about the ground but I don’t see a need for it.
www.BAKingHomeInspections.com
Originally Posted By: mcyr
Mike is correct in saying that it is a parge coat. This parge coat on block work will show evidence of settling and shrinkage over time and not necessarily show signs in the doors, drywall, floor structure above and etc..
I would note it as identified cracks in the foundation showing stress or shrinkage, but no evidence of shifting or settling was observed in the walls above. Recommend the the cracks in the foundation be monitored for any further movement.
Marcel
See, that is what happens when you post too late at night.
After reading the other posts and taking a second look, I now see the "parge coat" and agree with everyone above....except my own post.
The differential movement would be a step in the flat service of the concrete. This is a sign of movement. I would expect to see other signs of movement in drywall cracks, large stucco cracks, door or window issues, etc. And I agree that a soils engineer is a better call in these cases than a structural engineer.
Sorry for my last post...."my bad!"
Curtis
http://www.nachi.org/bbsystem/usrimages/C/_0321.JPG ]
[ Image: http://www.nachi.org/bbsystem/usrimages/C/ .JPG ]
[ Image: http://www.nachi.org/bbsystem/usrimages/C/Central_Ave_027.JPG ]
James;
What was the condition of the foundation, supports, etc..?
Marcel
Marcel,
Almost all homes here in central Texas in the last 20-30 years are slab-on-grade. Impossible to see what the slab is doing usually, so you have to rely on other tell-tale indicators.
James,
The second set of pictures and indicators are definitely troublesome. I would probably recommend a further inspection by a qualified, licensed foundation repair company.
Mike Boyett
Austin, Tx
Mike;
Educate me;
What are the remedial possibilities of a slab on grade in that area?
What causes such movement on the interior as your photos showed?
Obviously there has been movement and caused by what?
Expansive soils, bog, settling environment of the soils by erosion, ??
Marcel
Micheal, I did recommend further evaluation. I got to inspect two more of these homes and found similar situation. I was wondering why the owner was painting all the walls and putting in new tiles in all four of these houses.
Marcel,
To my knowledge the same issues that cause problems elsewhere cause problems here, i.e. expansive soils, drainage, poor installation, etc, etc. We have one additional problem here and that is underground caverns & erosion. Much of the Texas hill country is over limestone formations and underground aquifers. While we don’t have the sinkhole problems that plague Florida we do have movement caused by the underground erosion.
There are several repair methods but one I’m most familiar with is http://www.cablelock.com/ . Look at the section on “Cable Lock System” & it will show the repair process.
Mike Boyett
Austin, Tx
icon_smile.gif icon_smile.gif Thank you Mike;
This was a very interesting topic and now I am a stronger believer in a real foundation in Maine. ha. ha.
Marcel
Thanks
Originally Posted By: rcooke
mboyett wrote:
Marcel,
There are several repair methods but one I'm most familiar with is http://www.cablelock.com/ . Look at the section on "Cable Lock System" & it will show the repair process.
Great info thanks .
Roy Cooke Sr.
http://Royshomeinspection.com
Engineer looked at all of the properties. Repairs are needed at all of the properties. I showed up to engineers inspection and gained some knowledge. Hope the buyer has got some extra change. Thanks for the help.
Originally Posted By: whandley
Hey James;
Check out this website:
http://www.houston-slab-foundations.info/
![icon_idea.gif](upload://6VKizmOm2U7YYmfXNtFW4XTwFVy.gif)
