I looked in the Attic from the access in the Hallway. The Attic looked great with no signs of water penetration. But I did see light coming thru from a point the the Attic peak.
Would this be a concern? Roof looks good, Attic looks good.
Is seeing light coming from a point in the Attic peak a problem?
A write up would be totally dependent on you doing a thorough eval from rooftop and attic, gathering the facts.
In this case, you may have left the job without all the facts. Can you post photos?
Would it be possible for you to go back and check again? Hopefully it’s a vacant house that you can go back to tomorrow am without anyone needing to know.
I would be scared to put anything in the report about “seeing the light”, if I didn’t get in the attic to confirm where it’s coming from. In a dark attic and properly vented (soffits,ridges,gables) you should see light.
If you could not personally access attic to get a positive view of where light maybe coming from it would be in your best interest to call it out and refer further evaluation.
Don’t care about that. Post what you got, please. You’d be surprised what ‘others’ see in a pic. There may be tell tale signs leading to a possible answer for you.
