http://www.nfpa.org/assets/files/PDF/necdigest/NEC2008ProposalForm.pdf
Proposal:
Ask that NM, NMC, and NMS be revised as NM-B, NMC-B, and NMS-B throughout the NEC.
Reason:
Because, NM, NMC, and NMS are not permitted to be used.
The -B is the key, and is the correct way to determine if the product is used properly.
There is only one fine print note on this in the 2005 NEC and that's not enough!
Joe Tedesco, NEC Consultant
www.nachi.org/tedescobook.htm
