Septic Dye and Frozen Ground
Originally Posted By: rkuntz
Does a septic dye test work when the ground is frozen? It would seem to me that with frozen ground conditions even if there was a problem, the dye would be trapped underground.
Ronk
Originally Posted By: ismetaniuk
This membership was a big waste of my time!!!
Igor
Top To Bottom Inspections
Glen Spey, NY
Originally Posted By: nlewis
Of course, the breakout is not the only indication of a system failure. The septic tank cover should be removed or at least the cleanouts opened to measure the level in the tank and the observation ports opened at the drain field ,if they are present. The dye test generally finds only the obvious failures of the drain field.
