Originally Posted By: jpeck This post was automatically imported from our archived forum.
On-site septic system not inspected, recommend having septic system pumped out and inspected by a septic system contractor.
Also be advised that when a small family moves out and a larger family moves in and uses more water, the septic system will be stressed and could fail. The same with a large family moving out and a smaller family moving in if the smaller family uses more water.
The above is a very good reason to have the septic system pumped out and inspected by a septic system contractor.
Now, you told them:
a) You did not inspect it.
b) They should have it pumped out and inspected.
c) Explained briefly WHY they should do the above.
d) Then you told them again to have it pumped out and inspected.
