Septic testing vs septic inspection
I am in Indiana and had a septic system installer call (pretending to be a customer looking to have a home inspection performed) and started asking me if I did septic inspections. I informed him that I do septic testing, explained to him that it is a simple load and dye test, locate tank and field if possible, and visually look for any signs of failure. I also informed him that we do not perform any types of scoping with cameras. At this point, he asks if I am certified to perform septic inspections and I told him no, and that I only do septic testing.
He then starts yelling and stating that hes going to turn me in to the State and hangs up.
Do you need to be a certified septic inspector to perform septic testing?
Here’s what AI has to say about it.
do you need to be a certified septic inspector to perform septic testing in indiana? - Google Search
In Indiana, requirements for septic testing and inspection are largely determined at the county level, though most counties require individuals to be licensed or certified to perform these services professionally. While there is no single statewide license, many Indiana counties recognize or mandate certification through the Indiana Onsite Wastewater Professionals Association (IOWPA).
Key Certification and Licensing Details
  • County-Specific Rules: Licensing is managed by individual health departments. For example, St. Joseph County requires a specific registration and a $250 fee for inspectors.
  • IOWPA Certification: This is the industry standard in Indiana. To become a certified inspector through IOWPA, you must complete classroom training, watch inspection videos, perform five “job shadow” inspections, and pass a final exam.
  • General Home Inspectors: In Indiana, septic inspections are typically considered outside the scope of a standard home inspection. General inspectors are often prohibited from testing septic components outside the home’s foundation unless they hold specific septic credentials.
  • Real Estate Requirements: During property transfers, some counties (like Monroe or St. Joseph) require that a “qualified person” or the health department itself conduct the inspection to ensure compliance.
  • Homeowner Exemptions: In many jurisdictions, homeowners are permitted to clean or service their own residential systems without a permit, but they cannot perform inspections for others or for official real estate transactions without proper certification.
Professionals and Agencies in Indiana
If you are looking for a professional to perform a test, you can check with your Local Health Department for a list of registered inspectors in your specific county.
Timothy, check with your local health department. They should be able to tell you what you can and cannot do. The state recently passed a law banning mandated septic inspections, which essentially eliminated the requirement to be certified locally; although I thought that was meant to specifically target Allen County.
To me, changing the name can be confusing to customer and a way of circumventing regulations. I can see why he is upset.
Why? Do you know for certain that septic inspections are regulated in his area?
I don’t know the specific regulations. If you are purposely changing the title (testing), you know you are not offering the same service (inspection) as those that are. Customers can be confused by this.
If the service is a plus-cost item, then I think that gets into the gray area (so to speak). Just like swimming pools, movie stars, other installed equipment that is not part of the normal SOP, I’ll look at the visible connections and call anything out that looks wrong or old or rigged. But I wouldn’t call that anything other than part of the home inspection.
A dye test is GREAT for failing a system, and useless for passing it. I use dye tests all the time, covertly, but only reveal that I did if it fails. If you don’t find dye after a dye test, you don’t know or have anything to report. Again, dye tests only work to fail systems.
That is a semantic sleight of hand that has little difference in definition or meaning in this context. As Richard said, contact your local health department. It’s easy to get started with some side service that you actually need a license to do. A buddy of mine who had been taking samples for asbestos testing for years was reported by a disgruntled client. None of us knew that Colorado had passed a law requiring a license for this, but we know now after he is out $7k for it. BTW, his defense was that he wasn’t testing for asbestos. He was simply taking a sample that he sent off for testing to a lab. The state was unimpressed and said, “Same thing.”
That is what the OP is asking about. Only his local DOH can answer that, not some random guy from Iowa.
You’re talking about managing client expectations.
Geography does not negate what he is doing. Why do you think he is purposely making a point that he is not doing a septic inspection and it’s only a septic test?
Let’s says that he reports that there were no problems with the septic system. Two weeks after moving in, the system backs up. The septic guy (same guy that yelled at him) shows up to pump out the tank. He finds significant problems with the tank. What service did Tim provide for the customer? The customer believes that they paid for a service that told them the condition of the system.
Managing client expectations keeps you from your lawyer trying to manage the judge and jury’s expectations.
Nobody has to agree with me. In my opinion, you have to sometimes change your mindset as an inspector into the mindset of how you want a professional to treat and charge your parents or grandparents.
As Lon basically stated, it doesn’t really matter what you call it. Either he can legally do what he’s doing, or he cannot.
I do not disagree with you about managing customer expectations. It’s pivotal in our line of work. That just wasn’t the question that he asked.
His question does not make sense. Why would a certified septic inspector perform limited septic testing and not an actual septic inspection?
I don’t know. :person_shrugging: Maybe the OP doesn’t want to dip and clean a sludge judge. :poop:
System failures aren’t only when sewage is backing up in your yard. The system can also fail when sewage breaches the perimeter drain. That’s where a dye test comes in.
I’m not certified, but for an additional $50 charge, I’ll eat at Taco Bell the night before the inspection. :blush:
Seriously though, leave the septic testing/inspection to the septic companies. The tanks need to be pumped in order to provide anything useful to the client, in my opinion.
You can make it through a whole night?
100% agree with you. It’s the same as inspectors performing sewer scopes and then coming on here and asking what type of material they are looking at. Find a good sub to work with so you can provide great service.
So far, but I’m just 51 or so.
Luckily (I guess), in my area, septic systems are required to be tested and certified by a licensed septic contractor prior to a real estate transaction. So sellers have it done before even putting the home on the market.
They are here as well.
Hey, don’t dis on the Bell. I had the Bell yesterday, and almost made it through the whole night.
