Originally Posted By: loconnor
Dave C
I have read an article on dye testing. In this article it stated that one has to be careful in using the brand and make of the dye material in order to determine the validity of the test.
Have you had any questionable results from your tests, problems with the dye, and where do you get your dye?
I have some stiff competition here in this area, so my way of standing out above the rest is including a free water analysis test as part of my inspection. The analysis test is limited to Coliform/ecoli, and nitrate testing, but for a $27 lab fee to perform those tests, it's worth it.
The lab is close by here. I can drop it off and have the results in 2 days.
If additional water testing is required, then extra fees are charged.
Larry
Western Michigan NACHI Chapter
http://www.w-michigan-nachi.org
"We confide in our strength
without boasting of it.
We respect that of others
without fearing it"
Thomas Jefferson
