Service entrance wire size
Originally Posted By: mmcadams
I sub-contract for a another home inspector in central Florida area. My questions is with regards to the wire size from the weather head to the service panel. He is requiring wire size be noted and called out if incorrect for the Service panel amp size, IE 2/O, 3/O and 4/O. we are not state cert electricians and it is on the edge of calling out electrical code. Is this excepted notation on reports ??
Originally Posted By: jpope
It’s not about “code,” it’s about safety. If the service entrance cables are improperly sized, it’s imperative that it is noted in the report.
Jeff Pope
JPI Home Inspection Service
“At JPI, we’ll help you look better”
(661) 212-0738
Originally Posted By: wdecker
I check every wire gauge I can find, service entrance and branch.
It is not for code complience, but safety complience. Here, they are pretty much the same thing.
Hope this helps.
Will Decker
Decker Home Services
Skokie, IL 60076
wjd@DeckerHomeServices.com
