Townhouse built in 1986, this looks wrong, snow can build up around meter. Several other neighbors town-homes had the same issue. If I call it out will the utility company really come out and fix? (I know its’s not my problem) Looking for a height requirement.
Here you Go, I would write it up . check with your utility company
https://www.google.com/search?q=Electric+Service+meter+height&tbm=isch&tbo=u&source=univ&sa=X&ei=VHLBVKygG6GLsQTkoILQCQ&ved=0CCcQsAQ&biw=1366&bih=655
Thanks, found that PEPCO require Min 3’ Max 6’ to center of Meter.
Wow, Good Catch:mrgreen:
How did it get that way? Installed or landscaping fill brought in (house on a hill). Someone has been lucky seeing all that rust. :shock:
No issue.
The power company told them to “ground” the meter can! :mrgreen:
