Hi all,
I’m tempted to write this up as a damaged ABS sewer-line elbow. Are these just glue runs, or damage?
Thanks.
Hi all,
Thanks.
Did you get any closer images of it? Which direction does the elbow head from where we are looking at it? The image resolution and light exposure is kind of lacking. Also, if you’re able to put the video up on YouTube I would watch it for you when I get a chance.
Hi, Binyamin.
Welcome to the InterNACHI forum.
I see a crack that the 07:00 o’clock position of what appears to be a tee spigot that flares off to the left 2" down. The pipe hub should hold the cracked spigot in place.
As for leaking? I can not see how much seepage would develop unless the pipe blocks further downstream.
Is that a sanitary tee?
I would report my finding.
Suspect: Damaged spigot. Further evaluation by a licensed plumbing contractor.
That is my wag.
Do you future clients a favor and let the experts scope and evaluate the sewer pipe. You are not qualified.
There’s no way to tell by the picture you posted.
I recommend you join InterNACHI and take the free courses on scopes and plumbing systems.
Until then, you should consider subbing out your sewer scopes to a qualified Plumber.
Residential Plumbing Overview for Inspectors Course - InterNACHI®
