Hi everyone,
For foundation anchor bolts in residential or light commercial construction, when would you expect hot-dip galvanized anchor bolts to be used?
I understand that local code, treated lumber, exposure condition, and project specifications all matter. But in practical inspection or construction work, do you usually see HDG anchor bolts specified for exterior or moisture-exposed conditions?
Also, should the nuts and washers match the same coating?
Yes, anchor bolts should be hot-dipped galvanized for exterior conditions. And my preference is that all anchor bolts embedded in concrete be galvanized.
Corrosion-resistant.
International Residential Code (IRC Section R403.1.6), foundation anchor bolts must be at least ½-inch in diameter, embedded a minimum of 7 inches into concrete or masonry, and spaced a maximum of 6 feet apart with at least two bolts per plate section.
[According to InterNACHI and building code standards (IRC R403.1.6), residential foundation anchor bolts are typically low-strength steel (commonly ASTM A307 or ASTM F1554 Grade 36), must be at least 1/2 inch in diameter, and must extend a minimum of 7 inches into concrete or grouted masonry. [1, 2, 3]](Securing the Perimeter: Inspecting Foundation Anchor Bolts and Sill Plate Protocols (IRC R403.1.6) - InterNACHI®)
This poster is likely a team member of or has a marketing firm. They make these posts, then drop in links to websites they are trying to get high PR back links.
This is spam.
