Should this breaker have a handle tie
Should this GE breaker have a handle tie, there are 2 hot conductors entering breaker. Does this need a handle tie?
No, it is a tandem breaker and operates independently.
If that is a MWBC then the handle tie is required. A red conductor may indicate that it is a MWBC.
Given the age of that panel it probably wasn’t required when the panel was installed. If that is a MWBC it should also be verified that the two circuits are on opposite legs.
