inspecting this two-story home in Michigan and noticed during framing that the sill plate overhangs the concrete foundation by about 1 inch along one entire side of the house (about 40 feet) .
I wanted to ask the experienced inspectors and builders here:
Is a 1-inch sill plate overhang considered acceptable practice, or could it present structural or weather-sealing issues down the road?
Are there specific Michigan Residential Code (MRC / IRC) guidelines or bearing requirements I should be aware of for a two-story structure?
What key details should I inspect (e.g., anchor bolt positioning, sill seal/flashing, joist bearing) to ensure it’s properly supported and protected from moisture?
How bad of a problem it is depends on how the floor and rest of the house is framed. I’m assuming I-joists are being used from the rim boards that are visible.
Is the wall above the overhanging area a bearing wall? What does it support? 2nd floor load? Roof load?
Building codes require that load-bearing wall plates maintain full solid bearing contact across the foundation to safely transfer structural loads down without causing cross-grain bending failure.
But local AHJ’s often allow for minor offsets (such as accommodating exterior foam insulation board or slight foundation misalignments) and sometimes permit small tolerances up to 3/4 inch or 1 inch, but any major offset requires an engineer’s review and approved retrofit (like adding steel angle supports or concrete grouting).
Thanks Lon, what’s generally considered an acceptable tolerance for overhang around here?
I measured the entire 40-foot run, and the overhang actually varies anywhere from 3/8" to 1-1/2" along the line. It’s a 2x4 sill plate, so at that 1-1/2" mark, practically almost half the plate is hanging off the edge.
i’ve seen it a lot back in the late '90s in columbus oh when building houses for m&i and dominion. we did it regularly to square up the foundation when it was off (about half the time) but not more than an inch from what i recall. it’s not ideal but as long as the wall is not a bearing wall the normal 1 1/2" of full bearing should be sufficient, or at least that’s what i was told at the time…
Sometimes, a call to your local AHJ settles it. But part of the answer often has “depends” in it. Bearing on 2" of sill plate on a wall that is bearing two stories of exterior wall and roof eave for the full length of the wall would likely be too far over the tolerance line for most AHJs and engineers. But everything the same for only a few feet is more likely to be tolerated.
Yup. That’s the most common reason. Back in January on a new construction, the sill plate was hanging off the end of the foundation about 3". The city (AHJ) had either not caught it or signed off on it, but I said this was too much. The builder formed up a little concrete cap to put concrete under it. I advised my client of my skepticism and advised him to keep an eye on that. I’ll be back for the one year anniversary inspection and will see how it held up in this first year.
The foundation anchor bolt is required to be within the center 1/3 in the sill plate. Very easy to be off center when you’re more than 1/2 inch overhung beyond the foundation. Okay then how do we fix that? you have to add post installed foundation anchors to address this problem. Too bad you only have a 2x4 sill plate and don’t have enough foundation edge clearance for typical wedge, screw, or chemical foundation anchors, which can drastically weaken the holding power of the anchors. Now, since you are in Michigan, I’m assuming you don’t have earthquakes, hurricanes, or tornados? So you’re not likely to have catastrophic failure even though the house is technically not properly anchored to the foundation.
With an I-joist system, one of the structural functions of the rim board is to is to transfer vertical/gravity loads from the wall to the sill plate(to essentially bypass the I-joist) and then to the foundation, because the ends of the “I” of the I-joist can buckle/crush and fail if used to support a bearing wall. Most I-joist webs are 3/8 inch to 1/2 inch thick and I-joists are run at 19.2 inches on center typical. Compare that to a stud wall…do you see the difference?
Now a rim board is typically 1-1/8 inches thick. At 3/4 inch sill overhang, 66% of the rim board is not fully supported to the foundation. At 1 inch sill overhang 89% of the rim board is not fully supported. At 1-1/8 inch sill overhang, the rim board is 100% not fully supported. At this point, you are hoping that 1-1/2 inch thick sill plate is not going to shear off past the foundation when you are trying to support one whole side of the house on it. Again, how bad this is, depends on what that rim board is supporting above(roof live load(snow)?, floor live loads? dead load of framing, siding, windows, and other components?).
You can also think of the overhanging sill plate as a cantilevered beam. The top of the beam is in tension over the cantilevered portion of the wood. With a normal cantilevered floor joist, the wood fibers are being stretched to resist that tension at the top of the beam. With a sill plate, however, the wood fibers run parallel to the foundation wall. So you are actually pulling the wood apart between fibers, also known as tension perpendicular to the grain, which is very weak.
No matter what, the sill overhang falls into needing engineering evaluation so send that off to a structural engineer and he will decide the reinforcement required.
as someone who is still trying to get my inspectors license, I am unsure what codes the codes would say on that or how big of a defect inspectors would see this as. But as my own house project GC I know if I saw that I would have fired my whole framing crew on the spot
Please take a look at my latest reply to Yu Zhang for a full update on the measurements and the builder’s proposed fix.
It turns out the builder mixed two different sill plate sizes along that 40-foot run—20 feet with a 2x6 plate (minimal overhang, ~3/8" or less) and 20 feet with a 2x4 plate where the overhang ranges from 1" to 1-1/2".
The builder is offering to install solid concrete blocks between the brick ledge and sill plate (secured with concrete) for overhangs over 1", and apply concrete directly underneath for areas under 1". Given your previous experience with builders pouring concrete caps on brick ledges, I’d appreciate your thoughts on whether this is actually a sound structural fix.
I’ve actually been checking out several other new builds in the neighborhood being constructed by various builders, and I’m consistently seeing a mix of 2x4 and 2x6 sill plates used here in Michigan. It seems like it might be a common regional framing practice around here, though building standards might be different in your area.
It might be “OK”, but as Brian points out, the plan and execution should be reviewed by a structural engineer, rather than you (or any home inspector) taking ownership of approval.
…if you give the builder a green light on his proposed fix, you are signing up for responsibility/ownership and you don’t want that as Brian and Lon rightly point out.
