I need a little QUICK feedback from my fellow NACHI inspectors. Does anyone see any issue with this skylight install? I ask because I truly need some honest feedback. Roof was redone 6 months ago. Interior portion of the chased looked good. Please reply!
Start here: This Old House
Anderson Windows and Velux are two quality manufacturers I used as a builder. Go to their website and review their installation guide.
What do you see that makes you concerned, or are you looking for basic guidance on how to flash a skylight? Are those drone shots or were you up on the roof? This information would be helpful.
Are you qualified to inspect the skylight?
Yes sir I am qualified and sometimes I second guess myself. Those are not drone shots; I do not use a drone.
Heavy mastic at base, screws/fasteners that in my view will rust overtime, I see no step flashing (i know it is a prefab unit)
If installed per manufacturers instructions you do not need roofing tar or caulking around the perimeter.
The way I see it, if it’s not leaking anywhere, then it’s not an issue.
Is the bottom flashing butted up against the skylight or tucked into?
The three tubes of caulking they used on it does not give you a lot of confidence.
Are you asking a question or saying it is not needed around the perimeter?
Great - then if loose receptacle works it is fine too.
@dguenette Sorry for being snarky, but “do you see anything wrong” questions from a CPI aren’t the kind of questions appropriate for the CPI title. Your reference to mastic, screws, missing step flashing are what I expect to see. Thanks for the clarification.
There are all kinds of installation systems for various skylight brands. Some are good, others prone to leaking. All do have flashings, but there are many details that vary among manufacturers. Reviewing manufacturer installation instructions gives you guidance.
Sounds like you answered your question; lots of mastic, missing step flashing, exposed screws… Evidence of leakage or condensation in and around the skylight shaft is important to recognize, as you surely know. In my report, your roof side observations are what I’d report, along with a comment as to whether or not there is moisture staining in and around the skylight shaft inside the home. You have to CYA for both poor installations along with poorly designed skylight systems.
Next time, post your pictures and observations and ask for comments. I promise to be patient and provide another set of eyes and observations.
How many layers of roofing is on the roof? It looks like a roof over and the roofer just butted the new roofing to the sky light using tar and caulking to seal it.
What does this have to do with a receptacle?![]()
Kevin Leonard thanks for the reply and the conversation. Michael Senty if you EVER see my posts feel free to disregard and DON NOT REPLY. …“do you see anything wrong” questions from a CPI aren’t the kind of questions appropriate for the CPI title.
I have been doing this for 10 years, sometimes we all need to second guess our gut. Your answer is not an answer for this message board. You should be stricken from this board in my view.
I asked a question trying to help you and you ignored it. You get defensive with Thomas, Scott, & Thomas when they gave their input.
Are you here to find answers or just here to argue?
What a Snowflake! ![]()
It looks like it does not have any flashing. That DWV with flashing is telling me that you have multiple layers of shingles on that roof and they most likely shingled over the old flashing.
Not if the receptacle is leaking! Hardly a good comparison. Is the skylight loose?
I concur. No step flashing on the sides of the skylight.
Step flashing allows shingles to move independently on sloped roofs as the roof deck expand and contract vertically and horizontally which is a critical feature for preventing water infiltration.
After speaking with both the county inspector and the roofer it would appear the skylight has integrated Flashing: The unit comes with a built-in flange and perimeter frame that is manufactured as part of the skylight. The flange sits flat against the roof deck and is then shingled over.
Sometimes if you do not second guess yourself you will not learn there is a new product out.
For those of you that actually attempted to help, much appreciated, Marc G, Jeff B, and Kevin L. True pro’s. THANKS!
