[quote=Brian A. MacNeish]
When we see the stuff, why do we have to test for it??? Are we supposed to make $$$$$ at every chance…even when not needed? Come on, get real about things!
Here’s what I see going on too much: **Scare the sh!t out of them; then pick their pockets!!! **
Saved a family about $8,000 (quote from the area’s largest engineering company) on a “mould cleanup” two summers ago. Gave them info so they could do it themselves- my charge $60…I was inspecting on the next street that day and spent 15-20 minutes on site. The “mould” problem was: (1) an attic that looked like the initial picture (no real need to clean that mould- just change the conditions to provide a dry sheathing year round; (2) less than 10 sq ft of dark mould in a basement corner; (3) a 1973 rotting softwood garage door (eng. co’s comments: Do not go into the garage- hazardous to your health.) The decay mould was white filamentous mycelia…very similar and maybe the same species as the decay fungus you see rotting dead spruce, pine, fir trees in the forest!!! Then I guess the corollary would be: DO NOT GO INTO THE FOREST- HAZARADOUS TO YOUR HEALTH. COME ON!!!
From America’s preimminent building scientist:
"If you see it or smell it, you do not have to test for it. It is more important to get rid of the mould ( or conditions) rather than spend a lot of money trying to find out more about it***.***" (by sampling and identifying the species of mould- our comment) Dr. Joe Lstiburek, P. Eng., Phd…; Building Scientist and principle at Building Science Corporation (Website: www.buildingscience.com)
Quote:
Originally Posted by fcarrio
Robert,
I have seen this condition many, many times and it always turned out to be mold.
I STRONGLY recommend that you have a swab send to Pro Lab or another Bona Fide mold testing facility ASAP and certainly before closing.
***IF ***your client does not want this home tested for Mold then be SURE that you get a DISCLAIMER.
Good luck
Brian,
**First of all, there are many, many different types of mold. Some of them are harmless and others are toxic **and can either make you extremely ill or even incapacitate you . **
Purchasing a home is usually the largest purchase anyone will ever make. You must remember that this inspector went into a home that his client is considering purchasing and living in this contaminated home for many, many years or maybe even the rest of their life.
**At the present time I am involved in a court case where a home inspector conducted a “visual inspection” according to the ASHI standards of practice. This inspector walked through a room in a basement that was absolutely saturated and I mean saturated / covered in mold. **
**The mold was highly visible on the ceilings, walls, and floors. According to the ASHI standards of practice he did not have to report on the mold. Does that mean that he could ignore it? **
You might say yes but the law and the court system said that any reasonable man would have suggested at the very least, and I repeat at the very least that the client should have been alerted to the fact that some of this mold could be potentially toxic and or harmful to his health.
**Remember that all Standards of Practice are ****Guidelines ****and are NOT Law. **
**The sad part about this situation is that the client is a handicapped Vietnam veteran who is confined to a wheelchair with a *severely compromised immune system *and is extremely “visually impaired” so he could not see the mold even when he was standing in front of it. **
**He purchased this home “in good faith” based on the “Certified Home Inspector’s” report that failed to mention that the entire basement, and attic were absolutely saturated in mold. **
**You did not have to be a ****Home Inspector to see it. **
**Obviously this inspector thought that if he inspected according to "his" standards of practice that he was not obligated to report on the presence of mold. Also like you, he probably thought that it was “not needed”. Well guess what? He could not have been more mistaken. **
Here’s what I see going on too much: **Scare the sh!t out of them then pick their pockets!!! **
Informing your clients that there is mold in their “POTENTIAL” home is not scaring the sh~t out of them is called being responsible!
**Why would you NOT report the fact that there is mold in the home? **
**Why would you NOT suggest that the client have the mold tested to see if it is toxic or not? **
**Unfortunately in this case the homeowner found out about the TOXIC mold after he bought the house. How did he find out? He spent $90,000.00 on renovations and the contractors kept coming up with "excuses" that they were falling behind schedule because everyone was getting sick with the “flu”. **
**Finally the “light bulb” went on when two out of the eight workmen had to be admitted into the hospital! **
It turns out that the basement, the attic and the interior of each and every wall of this house was severely contaminated with Stachybotrys Chartarum!!
**This house is so severely contaminated with Stachybotrys that it has been deemed to be uninhabitable. It would take more to mitigate the mold than the house is actually worth! **
That is right Brian, it has been condemned and the homeowner is suing the home inspector for the entire price of the home plus expenses for the rental property that he has been forced to move into.
If someone like you advised this homeowner to simply “clean up” the toxic Stachybotrys Chartarum without the expertise needed or any special protective clothing and or equipment then I am sure you would have been added to the list of defendants in this lawsuit
"If you see it or smell it, you do not have to test for it. It is more important to get rid of the mould ( or conditions) rather than spend a lot of money trying to find out more about it.
First of all, it does not take a lot of money to take air samples or a culturette /swab(s) and send in a small section of the contaminated plywood to identify whether the mold is benign or toxic.
**Second, if the mold is toxic the homeowner, prospective buyer and the people who are trying to get rid of it have got to be informed! **
**Sending an unsuspecting and innocent workman into a situation where toxic mold is present is irresponsible and bordering on the criminal! **
So this comment that you attribute to a “pre-eminent building scientist” does not ring true with me.
I cannot believe that anyone who has a basic understanding of what toxic mold can do to people would make such a ludicrous statement.
**The bottom line is that if there is suspected mold in the house any reasonable Home Inspector should advise the client about it and recommend that they have it tested to see if it is TOXIC or not. **
**This decision should be theirs and theirs alone. **
