I have noticed recently that some of the social media sites I follow regarding home inspections, seem to cause more damage using tools rather than just a visual inspection. Example: One inspector was using a screwdriver on a ceiling where there was a water spot. It was obvious there was a water leak somewhere above the ceiling, however this inspector kept “poking” holes in the ceiling causing drips. He then put a toothpick like flag in the holes marking out the defects. This was on a newly built house that had not yet been resided in. I can’t imagine the inspection process on newly built homes is any different. Does anyone know if there are different processes to go through when the house is brand new?
No different on new construction. There are things and places that we probe and probing will poke a hole sometimes. Done properly, you identify a defect. Wood rot for instance. What you describe sounds like an already significantly damaged ceiling that would need replacement anyway, BUT don’t go poking stains on ceilings that can be Kilzed and repainted after they have dried out.
I would not recommend doing that, or anything similar. Probing deteriorated wood at a deck is one thing, but poking holes in drywall is another.
It’s called the DA Syndrome! That’s what they made moisture meters for if you want to verify moisture is present. If the DA could reach it with a screwdriver then he should have been able to reach it with a moisture meter.
No different inspecting a new house from an existing home.
And some inspectors wonder why they have to deal with “Builder Requirements” just to step on the premises!!
Sounds like this inspector was influenced by HGTV shows and not sound professional inspection standards and procedures.
They are sensationalizing every defect no matter how bad the problem actually is to get clicks and views. I think that’s a bad road to go down.
Social media is really no different than “reality TV”. That is to say it’s mostly fake.
Most home inspector “content creators” or “influencers” (God help us) aren’t really looking to educate, but to shock and entertain (forgive the term: inspector p*rn). So if you must consume inspection content, do so with many grains of salt and don’t let it confuse you or affect how you do your job based on the standards. You’re better off following good builders or trades - the ones that teach rather than show the most terrible click-baity things ever - if you want to learn useful stuff (e.g., JlmWoodWorks or Winni.Designs). I follow three inspectors, but they are personal friends and I actually like their stuff - and they don’t go viral for causing major leaks with a shower pan test or beefing with other pros.
Maybe this is the wrong place to add another question regarding social media, but does an inspector need written permission from a homeowner to post pictures of defects or insights involving the interior or exterior of a home, even if there’s no identifying features/address included?
No.
But it’s in our agreement that we own the photos and can do whatever we want with them, just in case.
In 12 years, I’ve never once had an issue.
I wonder what an Attorney/Judge would say, as I can see a case being made for various complaints in a Lawsuit/Courtroom.
Regardless… as we already know… anybody can sue anyone at anytime for any reason!!
IMO, the best Defense is typically a strong Offense… e.g. just don’t do it!!
Just sayin’!
The thing is, is that your agreement is not typically with the homeowner, unless you are in an area where pre-listings are common, which is possible I suppose.
It’s a gray area kinda. If the pictures are close-up, and do not expose any personal or property-identifying information, then I don’t see a huge issue with it necessarily. But is it technically probably somewhat unethical? I suppose a little bit. Would you want pictures of defects in your own home used as marketing (often times with a condescending tone or caption) without your permission? That said, exterior pictures of areas that are visible to the public are for sure ok.
If you are going to use inspection pictures for marketing on social media, I would recommend making the shots tight to the actual subject, and skip the funny tagline and/or condescending tone that I see on too many. Keep it about education.
Then what exactly is the purpose of posting your own photos? Simply take your choice of the millions of defect pics already posted in Google, Facebook, and most anywhere else… unless of course you are simply posting… “Ooh… Look what I found. I’m an awesome Inspector. Hire me!” type photos!!
The TikTok videos and postings on social media that I have seen inspectors post have been about shaming contractors and homeowners.
One particular inspector posts a lot of TikTok videos of new construction. In one video he is making fun of the HVAC contractor for forgetting to set the condensing unit and the trim carpenter for forgetting to install all the trim. You can see in the video that tools and materials are still in the home, and the project is not complete. An inspection should not be taking place. But it gets reactions and clicks from uneducated viewers, and they think he is who they should go with if the ever need an inspection.
A year or two ago, one of my competitors did an ad on Facebook bragging about how he inspected a home that was only a few years old and discovered that the framing on the home was structurally unsound and a huge hazard. Because of him, the buyer backed out. He got the clicks, likes, and comments that he was looking for. What he also got were contractors and a structural engineer saying that the framing was correct and that there was nothing wrong with the home. He quickly removed the ad and post. It did the exact opposite of what he was looking for.
Instead of educating, they tried making themselves out to be heroes. They did nothing to educate or give inspectors a good name.
I would agree. There are plenty of stock photos out there.
That may not necessarily matter. There was a case a few years back in Indiana where the seller filed a complaint with the Attorney General against a home inspector that posted his house on Facebook with a derogatory comment. The inspector was sanctioned for “disclosing information concerning the results of a home inspection on social media”.
Did they have the homeowner’s and/or client’s permission for disclosure, either by way of agreement or by another way?
If he did, he didn’t submit any supporting documents. He was fined a whopping $5.00 fine.
Sue for what, though?
One would have to prove they were harmed by a photo.
Not “The inspector published a photo of my open neutral outlet, and I’m outraged!”
There would have to be actual damages/harm for a lawsuit.
99.9% of photos have no context. Most homeowners probably couldn’t identify a photo of their own attic or crawlspace or inside of their electrical panel, even if it was in front of them.
Now, if someone started posting photos of family pictures that were hanging on the wall, I could see a point.
I’ve been in plenty of celebrity homes and had chances to do so, but I don’t even take those photos.
If you don’t want the risk of being sued, stay away from anything having to do with Real Estate. Heck, better yet, don’t leave the house.
