Soggy spaces help
Originally Posted By: jhorton
I was called to do a crawl space inspection on a house today. It was very apparent that they have a water problem. Lowest point in the subdivision so they get a lot of run off from the surrounding properties.
Some improvements in the grading were obviously needed. The crawl space has a sump pump and was very muddy in the low corner. There was a small trickle of water coming from in though and/or under the block at the front of the house. Finished grade is above the grade under the house. Obviously they have a lot of ground water to deal with.
It's beyond my knowledge as to how to fix a problem like this. I didn't even know who to send them to get quotes on fixing the problem. It's just not common in our area. What profession would you send/recommend you client contact? I want to steer them in the right direction but I have no idea who.
Jeff <*\\><
The man who tells the truth doesn't have to remember what he said.
Foundation & Structural Renovations Inc
(256) 880-1901
3124 Johnson Rd SW
Huntsville, AL 35805
www.foundationrenovations.com
If they can't help, I'll bet they can provide a referral.
Erby Crofutt
B4U Close Home Inspections
Georgetown, Kentucky
www.b4uclose.com
Duplicate post.
Erby Crofutt
www.b4uclose.com
THANKS!! There not far from us at all!
Jeff <*\><
The man who tells the truth doesn’t have to remember what he said.
