I see solder up higher but not lower by the tank end. Where silver tubes go into the copper. Is this normal?
Yes.
The solder is in that ridge on the bottom copper fitting.
thank you both
the “ridge” is a crimped on copper fitting factory applied to the flexible appliance connector
