Looking for CA sop for HI anyone know if there is one and if so where I can get a copy??? Thanks for the help!
Brian,
California has no licensing or state SOP. Use your associations. Greg listed CREIA’s, you could also use InterNACHI’s or CalNACHI’s : http://www.calnachi.org/index.php?option=com_content&view=article&id=62&Itemid=102
not looking for creia…looking to see if theres an sop put out by the state???
thanks for the info i knew there was no licensing here in cal was not sure on an sop or not. thanks
No problem.
They’re all going to be about 98% the same anyways.
very true…ill stick with nachi
Residential SOP: www.nachi.org/sop.htm
Commercial SOP: www.nachi.org/comsop.htm
