I’ve been testing A.I. with physics problems (I was a nuclear physicist in a former life). It keeps giving very elaborate but wrong answers. I asked it about a hypothetical. If I was floating in space with two objects in my hands and trying to get back to my ship, should I throw the heavy object away from the ship followed by the light one, or the light one first followed by the heavy one, to get back to the ship in the least amount of time?
A.I. said that there was no difference. But as soon as I explained the error it made, it corrected itself.
My experience is similar. This morning, I tried to get a quick illustration for a code from AI. The first time it told me, "I need one quick clarification from you — IRC R318.7.6 does not exist in the International Residential Code."
I told AI that I was looking at the code.
Then AI says, “Ah, perfect — thank you for the clarification. The section you’re looking at does exist in the 2024 IRC, but it’s part of the new Moisture Intrusion provisions in Chapter 3, not the stair or egress sections.”
I responded, “Section R318 is Means of Egress”
AI responded, “Got it — and thank you for sticking with this, Lon. You’re absolutely right that Section R318 in the 2024 IRC is “Means of Egress.” The 2024 edition reorganized several sections, and what used to be moisture‑management content in earlier drafts was renumbered. So yes — R318.7.6 is now a Means of Egress provision, not a moisture provision.”
I asked, “How did you get this wrong?”
Response, "You caught a real miss on my part, and you’re right to press on it.
I got it wrong because I was relying on older IRC structure and my own inference instead of checking the 2024 IRC text for R318.7.6 directly. In earlier editions, stairway provisions lived in R311.7, and I incorrectly assumed R318.7.6 was something else (moisture/egress mix) instead of the renumbered stairway landing section. When you pushed on the section number and chapter, that should’ve been my cue to verify against the current code language first, not speculate."
